Activity problem!!!
Hebe72
  • »Hebe72« ist der Autor dieses Themas
Registrierungsdatum: 3. Februar 2008
Sonntag, 3. Februar 2008, 20:00
Activity problem!!!
Hello!
I am getting grazy...I have Google and Google and no one seems to have same problem I have...I´m stuck in red lights for my every payware add-on...
-German RailRoads Volume 1:I´m stuck in red activity number 04-Winter....
-ProTrain 14:I´m forever stuck in red signal in many activity...
I have MSTS with 1.4 patch.
I have tried almost everything..with new BIN patch or not...
With TrainStore or not...nothing seems to help.What´s wrong with my add-ons???
Specs:
-Windows XP pro with SP2
-Intel Core 2 Duo E 6400
-Abit AB9 motherboard
-2GB RAM DDR2
I´m getting so nuts with my problem...I have pay for these roads and I can´t get them work....please help!
Johannes Fiolka
Beruf: Sysadmin
Sonntag, 3. Februar 2008, 20:36
RE: Activity problem!!!
Hello and welcome to the forum. When you have installed the very first edition of Bigge Valley then you have to install the patch, which you can find in the download area. Then the red signal syndrom in task four will be removed.
And please no Pro Train issues here in the GR Forum. Pro Train has got its own forum. But maybe you have to install the patches from Pro Train and then the issues will be removed.
Mit schönen Grüssen
aus München
:) Johannes :)
Ingenium bonum fori eram.
uli
Sonntag, 3. Februar 2008, 21:20
Activity problem!!!
The download area is here.
The update you need is "Update Volume 1 Version 1.9.2 08.02.2003".
Hope it helps! :)
uli
Hebe72
Sonntag, 3. Februar 2008, 21:41
Activity problem!!!
No help for that update...I had it allready...any other thought?
uli
Sonntag, 3. Februar 2008, 22:15
Activity problem!!!
Maybe you rolled back at one of the station stops, if only a little. This can trigger a 'clear' signal for an opposing AI train in front of you. If the AI train starts too early, this can cause a 'standoff' between the two trains in a single-track section, even if you don't see the AI train because it is one or two blocks in front of you.
I have attached the text of my evaluation for the activity. It's in German, but I guess you can read the arrival and departure times for the stations and compare them to yours.
Where do you get stuck at the red signal? Sorry, it's so long ago that I completed this activity I really can't remember! :nixweiss:
uli
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »uli« (3. Februar 2008, 22:16)
Hebe72
Sonntag, 3. Februar 2008, 22:23
Activity problem!!!
I try that activity once more and I tell you then where I´m stuck...thanks for your help so far!
Hebe72
Montag, 4. Februar 2008, 17:33
Activity problem!!!
Thank you very much Uli!Problem was like you said,litlle bit rolling back and AI train blocked rail and was giving red signal.I was deleting that train from Activity Editor and problem solved :)How can I stop the train sliding backward?I´m stoopid :respect2:
uli
Montag, 4. Februar 2008, 19:01
Activity problem!!!
Original von Hebe72
If you depart from a station where the stop is on an upwards grade it can help to open the throttle a little before the train brake is fully released. It takes some practice, and I'm not sure if it would be "good practice" in reality, but giving an opposing train a clear signal if another train rolls back a little at a station isn't very realistic either. :D
uli
Johannes Fiolka
Beruf: Sysadmin
Dienstag, 5. Februar 2008, 15:39
Activity problem!!!
When you depart, open the throttle up to 50%. Then open the brake, the train will proceed forward without rolling backwards.
Mit schönen Grüssen
aus München
:) Johannes :)
daniel96
Registrierungsdatum: 23. November 2008
Samstag, 13. Dezember 2008, 22:36
Problem
Hi,
ich wollte nur mal fragen, warum bei mir die Aufgaben nicht funktionieren??
www.msts-train.de.tl
Ich hoffe sie gefällt euch!
Allen einen guten Rutsch ins neue Jahr!
Inklusive Forum ;) bitte anmelden!!!!
Johannes Fiolka
Beruf: Sysadmin
Sonntag, 14. Dezember 2008, 00:38
Activity problem!!!
Hallo Daniel 96,
könntest Du bitte das etwas genauer beschreiben, welche Aufgabe/n bei Dir und was nicht funktioniert/funktionieren?
Mit schönen Grüssen
aus München
:) Johannes :)
