Dieser Beitrag wurde bereits 1 mal editiert, zuletzt von »RK54« (3. Januar 2009, 02:44)
The engine file 701.eng contains an error on the line "Wagon ("and so it couldn't be added to the engines list.
Folder I:\Programme\Microsoft Games\Train Simulator\TRAINS\TRAINSET\DB701
The engine file 701gelb.eng contains an error on the line "Wagon ("and so it couldn't be added to the engines list.
Quellcode |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 |
SIMISA@@@@@@@@@@JINX0D0t______ Wagon (701 Type(Engine) Sound("701eng.sms") WagonShape(701.s) Size(3m 4m 13.95m) Mass(26t) InertiaTensor(Box(3m 4m 13.95m)) Coupling(Type(chain) Spring(Stiffness(5e6N/m 5e6N/m) Damping(5e6N/m/s 5e6N/m/s) Break(5e7N 5e7N) r0(20cm 20cm)) Velocity(20kmh) DerailRailHeight(10cm) DerailRailForce(75kN) DerailBufferForce(2000kN)) Adheasion(0.2 0.4 2 0) Friction(comment(Realmuto) 425N/m/s 0 1mph 11.5N/m/s 1.8 5.1N/rad/s 1 -1rad/s 0 1) WheelRadius(0.45m) NumWheels(1) AntiSlip() BrakeEquipmentType("Triple_valve, Auxilary_reservoir, Emergency_brake_reservoir") BrakeSystemType("Air_single_pipe") MaxBrakeForce(40kN) EmergencyBrakeResMaxPressure(110) TripleValveRatio(2.5) MaxReleaseRate(30) MaxApplicationRate(25) MaxAuxilaryChargingRate(20) EmergencyResCapacity(10) EmergencyResChargingRate(25) BrakeCylinderPressureForMaxBrakeBrakeForce(70) IntakePoint(0 0.8 FuelDiesel) PassengerCapacity(5 #for activity usage) Inside(PassengerCabinFile(701.s) PassengerCabinHeadPos(-0.35 2.5 -5) RotationLimit(80 360 80) StartDirection(8 185 0)) comment(----------------------------------------------------------------------------------------------------------------------------------------------------------) Lights(12 Light(comment(root) Type(1) Conditions(Headlight(3) Unit(2)) FadeIn(0.5) FadeOut(0.5) Cycle(0) States(1 State(Duration(0) LightColour(cdffffd5) Position(0 1.6 6.4) Transition(0) Radius(150) Angle(12)))) Light(comment(root for reverse) Type(1) Conditions(Headlight(2) Unit(3)) FadeIn(0.5) FadeOut(0.5) Cycle(0) States(1 State(Duration(0) LightColour(cdffffd5) Position(0 1.6 -160) Transition(0) Radius(150) Angle(12)))) Light(comment(vorne rot links) Type(0) Conditions(Headlight(2) Unit(2)) FadeIn(0.5) FadeOut(0.5) Cycle(0) States(1 State(Duration(0) LightColour(ffff0000) Position(-0.86 1.69 6.4) Azimuth(0 0 0) Transition(0) Radius(0.5) Elevation(0 0 0)))) Light(comment(vorne rot rechts) Type(0) Conditions(Headlight(2) Unit(2)) FadeIn(0.5) FadeOut(0.5) Cycle(0) States(1 State(Duration(0) LightColour(ffff0000) Position(0.86 1.69 6.4) Azimuth(0 0 0) Transition(0) Radius(0.5) Elevation(0 0 0)))) Light(comment(vorne weiß links) Type(0) Conditions(Headlight(3) Unit(2)) FadeIn(0.5) FadeOut(0.5) Cycle(0) States(1 State(Duration(0) LightColour(cdffffd5) Position(-0.86 1.69 6.4) Azimuth(0 0 0) Transition(0) Radius(0.5) Elevation(0 0 0)))) Light(comment(vorne weiß rechts) Type(0) Conditions(Headlight(3) Unit(2)) FadeIn(0.5) FadeOut(0.5) Cycle(0) States(1 State(Duration(0) LightColour(cdffffd5) Position(0.86 1.69 6.4) Azimuth(0 0 0) Transition(0) Radius(0.5) Elevation(0 0 0)))) Light(comment(vorne weiß top) Type(0) Conditions(Headlight(3) Unit(2)) FadeIn(0.5) FadeOut(0.5) Cycle(0) States(1 State(Duration(0) LightColour(cdffffd5) Position(0.0 3.4 6.3) Azimuth(0 0 0) Transition(0) Radius(0.5) Elevation(0 0 0)))) Light(comment(hinten weiss links) Type(0) Conditions(Headlight(2) Unit(3)) FadeIn(0.5) FadeOut(0.5) Cycle(0) States(1 State(Duration(0) LightColour(cdffffd5) Position(-0.86 1.69 -6.39) Azimuth(180 180 180) Transition(0) Radius(0.5) Elevation(0 0 0)))) Light(comment(hinten weiss rechts) Type(0) Conditions(Headlight(2) Unit(3)) FadeIn(0.5) FadeOut(0.5) Cycle(0) States(1 State(Duration(0) LightColour(cdffffd5) Position(0.86 1.69 -6.39) Azimuth(180 180 180) Transition(0) Radius(0.5) Elevation(0 0 0)))) Light(comment(hinten weiss oben) Type(0) Conditions(Headlight(2) Unit(3)) FadeIn(0.5) FadeOut(0.5) Cycle(0) States(1 State(Duration(0) LightColour(cdffffd5) Position(0 3.4 -6.28) Azimuth(180 180 180) Transition(0) Radius(0.5) Elevation(0 0 0)))) Light(comment(hinten rot links) Type(0) Conditions(Headlight(3) Unit(3)) FadeIn(0.5) FadeOut(0.5) Cycle(0) States(1 State(Duration(0) LightColour(ffff0000) Position(-0.86 1.69 -6.39) Azimuth(180 180 180) Transition(0) Radius(0.5) Elevation(0 0 0)))) Light(comment(hinten rot rechts) Type(0) Conditions(Headlight(3) Unit(3)) FadeIn(0.5) FadeOut(0.5) Cycle(0) States(1 State(Duration(0) LightColour(ffff0000) Position(0.86 1.69 -6.39) Azimuth(180 180 180) Transition(0) Radius(0.5) Elevation(0 0 0)))) )) Engine (701 Wagon(701) Type(Diesel) Sound("701cab.sms") DoesHornTriggerBell(0) CabView(701.cvf ) HeadOut(0 5 0) Effects(DieselSpecialEffects(Exhaust1(-1.5 0.5 -0.5 -1.5 1 0 0.1))) DieselSmokeEffectInitialMagnitude(2) DieselSmokeEffectMaxMagnitude(0.5) DieselSmokeEffectInitialSmokeRate(0.2) DieselSmokeEffectMaxSmokeRate(0.2) DieselEngineIdleRPM(300) DieselEngineMaxRPM(1000) DieselEngineSpeedOfMaxTractiveEffort(13mph) DieselEngineMaxRPMChangeRate(20) MaxDieselLevel(360l) DieselUsedPerHourAtMaxPower(50l) DieselUsedPerHourAtIdle(30l) MaxTemperature(120) MaxOilPressure(90) MaxPower(300hp) MaxForce(80kN) MaxContinuousForce(80kN) RunUpTimeToMaxForce(10) MaxVelocity(90kmh) MaxCurrent(1500A) WheelRadius(0.45m) NumWheels(1) BrakesEngineBrakeType("Air_single_pipe") BrakesEngineControllers("Independent, Train, Dynamic") EngineBrakesControllerDirectControlExponent(1) BrakesTrainBrakeType("Air_single_pipe") AirBrakesAirCompressorPowerRating(1.2) AirBrakesMainMinResAirPressure(0) AirBrakesMainMaxAirPressure(90) AirBrakesMainResVolume(8) AirBrakesAirCompressorWattage(19000) AirBrakesCompressorRestartPressure(87) AirBrakesAirUsedPerPoundsOfBrakePipePressure(0.22) AirBrakesIsCompressorElectricOrMechanical(1) EngineBrakesControllerMinPressureReduction(6) TrainBrakesControllerMinPressureReduction(6) EngineBrakesControllerHasProportionalBrake(1) EngineBrakesProportionalBrakeLag(0.9) EngineBrakesControllerMaxApplicationRate(20) TrainBrakesControllerMaxApplicationRate(20) EngineBrakesControllerMaxReleaseRate(15) TrainBrakesControllerMaxReleaseRate(4) EngineBrakesControllerEmergencyApplicationRate(50) TrainBrakesControllerEmergencyApplicationRate(50) EngineBrakesControllerMinSystemPressure(0) TrainBrakesControllerMinSystemPressure(0) EngineBrakesControllerMaxSystemPressure(90) TrainBrakesControllerMaxSystemPressure(90) EngineBrakesControllerEmergencyBrakeTimePenalty(60) TrainBrakesControllerEmergencyBrakeTimePenalty(60) EngineBrakesControllerFullServicePressureDrop(26) TrainBrakesControllerFullServicePressureDrop(26) EmergencyStopMonitor(MonitoringDeviceMonitorTimeLimit(0) MonitoringDeviceAlarmTimeLimit(0) MonitoringDevicePenaltyTimeLimit(0) MonitoringDeviceCriticalLevel(0) MonitoringDeviceResetLevel(0) MonitoringDeviceAppliesFullBrake(0) MonitoringDeviceAppliesEmergencyBrake(1) MonitoringDeviceAppliesCutsPower(1) MonitoringDeviceAppliesShutsDownEngine(0)) VigilanceMonitor(MonitoringDeviceMonitorTimeLimit(25) MonitoringDeviceAlarmTimeLimit(17) MonitoringDevicePenaltyTimeLimit(0) MonitoringDeviceCriticalLevel(0) MonitoringDeviceResetLevel(0) MonitoringDeviceAppliesFullBrake(1) MonitoringDeviceAppliesEmergencyBrake(0) MonitoringDeviceAppliesCutsPower(0) MonitoringDeviceAppliesShutsDownEngine(0)) OverspeedMonitor(MonitoringDeviceMonitorTimeLimit(0) MonitoringDeviceAlarmTimeLimit(0) MonitoringDevicePenaltyTimeLimit(0) MonitoringDeviceCriticalLevel(76) MonitoringDeviceResetLevel(0.1) MonitoringDeviceAppliesFullBrake(1) MonitoringDeviceAppliesEmergencyBrake(1) MonitoringDeviceAppliesCutsPower(1) MonitoringDeviceAppliesShutsDownEngine(0) MonitoringDeviceAlarmTimeBeforeOverSpeed(5) MonitoringDeviceDoesSuppressionReset(0) MonitoringDeviceTriggerOnOverspeed(74) MonitoringDeviceResetOnZeroSpeed(1) MonitoringDeviceResetOnResetButton(0)) comment(----------------------------------------------------------------------------------------------------------------------------------------------------------) EngineControllers( Throttle( 0 1 0.05 0 NumNotches(11 Notch(0 0 Dummy) Notch(0.1 0 Dummy) Notch(0.2 0 Dummy) Notch(0.3 0 Dummy) Notch(0.4 0 Dummy) Notch(0.5 0 Dummy) Notch(0.6 0 Dummy) Notch(0.7 0 Dummy) Notch(0.8 0 Dummy) Notch(0.9 0 Dummy) Notch(1 0 Dummy))) Brake_Engine(0 1 1 0 NumNotches(1 Notch(0 1 Dummy))) Brake_Train(0 1 0.05 0.5 NumNotches(5 Notch(0 0 TrainBrakesControllerReleaseStart) Notch(0.3 1 TrainBrakesControllerGraduatedSelfLapLimitedHoldingStart) Notch(0.8 0 TrainBrakesControllerSuppressionStart) Notch(0.9 0 TrainBrakesControllerContinuousServiceStart) Notch(1 0 TrainBrakesControllerEmergencyStart))) DirControl(-1 0 1 1) BellToggle(0 1 0) AWS(0 1 0) Sanding(0 1 0) Horn(0 1 0) Wipers(0 1 0) EmergencyStopResetToggle(0 1 0) EmergencyStopToggle(0 1 0) Vigilance(0 1 0) Headlights(0 0.25 1 0) BailOffButton(0 1 0)) comment(----------------------------------------------------------------------------------------------------------------------------------------------------------) Name("TVT 701 033-3 rot" #.eng-file layout by roje 11.2003. Feel free to use it in Your own files, but please keep this note) Description("Turmtriebwagen 701 033-3 der Deutschen Bundesbahn in klassischer roter Farbgebung. roje's msts designs TVT55 v2.0 11.2003 ist installiert")) |
Quellcode |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 |
SIMISA@@@@@@@@@@JINX0D0t______ Wagon ( 701rot Type ( Engine ) Comment ( "Created with EngMexx V0.72.0108" "Copyright (c) 2002-2003 Holger Maass" ) WagonShape ( "701.s" ) Size ( 3m 4m 13.95m ) Mass ( 26t ) WheelRadius ( 0.45m ) InertiaTensor ( Box ( 3m 4m 13.95m ) ) |
Dieser Beitrag wurde bereits 2 mal editiert, zuletzt von »bonner« (4. Januar 2009, 09:19)
